Starting Step's Per unit w/ Extruder
All things related to Mach3 CNC software
timothysvec
Post by timothysvec »
Greetings, what are you guy's using for a good starting point (before using axis calibration on the setting's screen) with the a axis extruder in mach 3. i'm using 1.75mm black abs from ulti machine.
cheers, tim
johnoly99
Re: Starting Step's Per unit w/ Extruder
Post by johnoly99 »
If you're in metric, try 284, if you're in inches, try 284*25.4
Return to “Mach3 Software”
