Print issues
Posted: Sun May 10, 2015 11:29 pm
by Gundy1024
So I have a question, I have been running now for 10 hours or so running test prints and I am getting dialed in but I have a issues I am not sure about. I have ramdom layers that will have a bit of overlap or slight hang over. Not dripping down but just not in line with the rest of the layers. As I said before it is completly random and I have not been able to key in on what is causing it. Any ideas? I will be able to get some pictures once this current print finishes, the others are small and hard to get a good detailed picture of this issue.
Thanks,
Re: Print issues
Posted: Sun May 10, 2015 11:47 pm
by Earthbound
A sticky u-joint can cause this. Quite common on the older aluminum ones. If you have the newer acetal type joint, then check for free movement of the arm through all positions. Sometimes a joint clip or fan shroud has a spot where they bump.
Re: Print issues
Posted: Mon May 11, 2015 12:08 am
by Gundy1024
Am I too assume that if I take the arms off one at a time to lube them and check got movement I would still have to redo my calibration?
Re: Print issues
Posted: Mon May 11, 2015 8:57 am
by Gundy1024
Re: Print issues
Posted: Mon May 11, 2015 8:40 pm
by Gundy1024
Also, can someone tell me about the two areas I have highlighted. Way is the square lop sided and why do my first layers look this way?
- 20mm Cube Bottom
Thanks,
Gundy
Re: Print issues
Posted: Thu May 14, 2015 11:09 am
Looking at the above square, the first thing that comes to mind is the slicer. Have you tried a different slicer then tried to print again?
My favorites are Cura and Kisslicer. Please let us know the result of using a different slicer.
Re: Print issues
Posted: Thu May 14, 2015 6:52 pm
by Gundy1024
Thanks Eaglezsoar, I will try that next. Was also wonder if acceleration or jerk setting could be causing it. If I print in spiral vase mode the prints come out flawless. But as soon as I print a regular object I get these horizontal lines.
