clic3r printed object with small gap
Posted: Wed May 13, 2015 6:52 am
by duvdev
Hi all
I am using repetir gost ans i yse the cura engine for most of yhe prints.
I got some midel with some overhand and I know cura is not so good at it so I used slic3r
the result o fthe part is good and the overhand turnout perfect but I have a small problem in the top am buttom layers - it seems like it wont fill it up 100% and you can see in the picture. It is also look like this in the software after slucing.
I use ABS and 245 deg with e3dv6 0.4 mm nozzle.
How can I solve it?
thanks.
Re: clic3r printed object with small gap
Posted: Wed May 13, 2015 7:26 am
by Mac The Knife
In advanced settings, you can change your extrusion width,,,, you can change that to eliminate it. by default it is set at .5.
