PEI not exactly flat, do I sand it?
Posted: Fri May 15, 2015 2:50 am
Hi guys,
I have a piece of PEI on the glass bed. It works wonderfully. I can easily pop prints off after the bed cools by 10C.
I was doing fine calibration and found out something interesting. Calibrating in front of each of the towers the bed is flat by .01mm. The problem is this.
I was doing single layer calibration circles and found that in front of the Z tower closer toward the center, there is a rise or something. Anyway, the spot of about 2x2 inches is higher than the rest of the bed by about 0.15mm. Should I just sand this spot down? What grit do I use to do this? 2000 grit for final finish of the surface after sanding?
It is really annoying to find a high spot on an otherwise flat bed.
Thanks.
Felix
Thanks.
Felix
