Noob Question
Posted: Fri May 15, 2015 9:21 pm
by Gundy1024
So I have what may be a stupid question but I can't seem to find the answer here so far. In matter control it shows my bed size as 150mm which equates to 5.9 inches. Should I have this set to 279mm being 11 inches? I notice that when I make prints they end up taking up a lot less space than matter control is showing they will which has kept me from trying bigger prints. Sorry for the noob question.
Gundy
Re: Noob Question
Posted: Fri May 15, 2015 9:24 pm
by TFMike
yes, and I would back off using matter control as well lol
Re: Noob Question
Posted: Fri May 15, 2015 9:37 pm
by Gundy1024
What would you suggest? I have repetier but have no clue how to set it up.
Re: Noob Question
Posted: Fri May 15, 2015 9:53 pm
by Tincho85
I tried to use MC, but the way it rotates the model is awful.
That made me uninstall it :P
Here, Repetier-Host Edition:
https://mega.nz/#!NZJiHQZC!zK-WtJlp_-Pp ... QEOpmJ_FMA
Re: Noob Question
Posted: Mon May 25, 2015 11:58 pm
by cyber.shifter
Tincho85 wrote:I tried to use MC, but the way it rotates the model is awful.
I've seen mention of using Repetier-Host in a couple places now, outside of these forums. I am hesitant to switch control programs, but I do get frustrated with MC. How easy is it to convert to using Repetier-Host, since I am still fairly new to the game? Tincho85 I'm pinging you on this, since you seem to have had the same thoughts and then made the switch.
Re: Noob Question
Posted: Tue May 26, 2015 12:26 am
by bot
The old version of the assembly manual details the way to set up Rep Host. I'll attach it here.
Rostock-MAX-v2-Assembly-GuideRepHostInst.pdf
(226.81 KiB) Downloaded 291 times
Re: Noob Question
Posted: Tue May 26, 2015 2:18 pm
by Tincho85
Oh no.. I never actually used MC. I tried to, but quit once I rotated a model.
If you have the time, give it a try. The link from Mega.nz is the complete guide with Repetier-Host.
Re: Noob Question
Posted: Tue May 26, 2015 6:11 pm
by bot
Oh oops. I didn't realize your link was also for the manual.
