Print shifting consistently
ericpudding
Post by ericpudding »
For every print lately I have had consistent shifts about an hour in. I have tried many different options but still have shifts. I tried tightening the belts and making sure the carriages were correctly tightened. After that didnt work, I thought the Rambo board was too hot and I have a desk fan aimed directly at it but still get shifts. I have also lowered the print and move acceleration. I have run out of ideas of what to do to fix it. Anybody have other ideas?
BenTheRighteous
Re: Print shifting consistently
Post by BenTheRighteous »
same model every time?
ericpudding
BenTheRighteous wrote:same model every time?
Yes. But I slice it again every time. And I have printed it successfully before with the same part file.
BenTheRighteous
Without having any idea what the model looks like, I'm guessing your travel move is too high.
If your model gets out to the edge of your print area, you've got to be careful with the speed of your travel move. Try lowering that a bit.
teoman
Post by teoman »
I think greasing my joints solved the problem.
teoman wrote:I think greasing my joints solved the problem.
I wonder if that would work with my arthritic joints? :)
teoman
Post by teoman »
Could do,
Take them apart and pump in some teflon :)
No, use bacon grease. Bacon fixes everything.
:D
barry99705
Post by barry99705 »
geneb wrote:No, use bacon grease. Bacon fixes everything.
:D
https://instagram.com/p/2N5UHfChAZ/
Nylocke
Post by Nylocke »
barry99705
Seeing Wolverine do it is just funny though! Aww, you didn't post the 12 hour version!! :twisted:
