3d model slicer software
Posted: Fri May 22, 2015 9:01 am
by predawnsky
do you guys to know where I can get a 3d model slicer software to make prints more manageable for my printer
Re: 3d model slicer software
Posted: Fri May 22, 2015 9:57 am
by Mac The Knife
Define "manageable".
Posted: Fri May 22, 2015 11:31 am
by predawnsky
With in the 11x14 space for my max v2
I have a massive build I want to do but I need to slice it into smaller pieces that my printer can handle
Posted: Fri May 22, 2015 12:10 pm
by Mac The Knife
Ahhh, Now I see,,,, you're looking for software to cut your model up into smaller sections that your slicer can generate code to fit the Rostock.
Posted: Fri May 22, 2015 12:42 pm
by Dale Eason
You can do that with MeshMixer, 123D, and FreeCad to name a few. I use 123D.
Posted: Fri May 22, 2015 2:10 pm
by predawnsky
Dale Eason wrote:You can do that with MeshMixer, 123D, and FreeCad to name a few. I use 123D.
what version of 123d do you use
Posted: Fri May 22, 2015 6:11 pm
by Dale Eason
predawnsky wrote:Dale Eason wrote:You can do that with MeshMixer, 123D, and FreeCad to name a few. I use 123D.
1.6.41 but the version should not matter they have had the split solid function for a long time I think.
Posted: Fri May 22, 2015 7:07 pm
by Mac The Knife
Posted: Fri May 22, 2015 9:25 pm
by predawnsky
thanks mac
Posted: Sat May 23, 2015 3:38 am
by teoman
Might want to add little holes and protrusions so it self aligns or better yet little tabs so it "clicks" back in to place.
Posted: Sat May 23, 2015 5:39 pm
by predawnsky
will do teoman
Posted: Mon Oct 08, 2018 8:18 pm
by RegB
Ahh yes, "massive" builds".
Not usually the domain of 3D printing, but it CAN be done.
I'm going through this now, since the PRACTICAL limit on ABS prints is about 10 cm - above that thermal stress and shrinkage cause cracking and/or deformities.
Solidworks can do it; basically you would need to design in the "joints", create assemblies from parts and use "mate".
Expensive unless you can get a student or ex military service purchase - or already have it funded for some other project.
Posted: Mon Oct 08, 2018 8:23 pm
by RegB
I can't edit the above post, but had meant to say that in Solidworks "mate" will help you figure out where and how your joints don't fit, e.g. a sliding dovetail needs to be right, and I mean JUST RIGHT for the assembly to go together.
It can still be worth taking off a TINY bit from each mating surface to allow for slight outer wall irregularities - or you'll be filing plastic.
Posted: Thu Oct 11, 2018 5:39 pm
by Xenocrates
Netfabb is pretty easy. I've attached the archived free installer (since pulled from the website, but it should still work). I've done some stuff with it, as well as using Maya and Fusion 360 for similar tasks, but Netfabb is way easier to just split things.
