Rollers, Bearings, Concentricity
Posted: Mon Jun 01, 2015 11:41 pm
Hi,
I've been working on making a big delta printer recently, but that's another thread on its own. This one is just about the rollers that will go on it.
Pictures first!
OK now the write up.
My big delta printer uses 15 series T slots, which are 1.50x3.00 inches. They have different slot sizes so I can't buy rollers from open source hardware stores. These are the rollers I made to ride on the linear carriage of the printer.
First, the basics. Each roller is made of an appropriate engineering polymer. Metal rollers would require tighter tolerances and smoother surfaces to work right, but they would still weigh more and would wear the anodized aluminum T slot without modifications. The rollers are 1.500 inches long like the T slot. There are two 13mm bore holes for 624 ball bearings on each side of the roller.
An M4 screw is put through the bearings, then nuts or spacers clamp the inner races together. This part is critical to the rigidity of the linear carriages. Without preload, the bearings could slide +-0.05mm axially. The preload makes everything stiff and precise to a few microns.
A hole of somewhat arbitrary size is bored through the center of the rollers. In this case it is about 0.26 inches in diameter, but it is not precise (nor does it need to be). The 13mm bearing holes must be as concentric as possible to the external roller surface, otherwise the linear carriage will be loose in some places on the T slot and tight in other places.
I tried to avoid this from the beginning but I don't have the measuring tools or machines to solve it. When I bored the second bearing hole on each roller, I had to re-chuck the whole part, which lead to about 0.002 inches of concentricity error. The carriage will still roll down the T slot smoothly, but it will accelerate and decelerate in a sine pattern in phase with the high and low points of the concentricity error. It still stays preloaded and accurate, but I know that it may be wobbling up to 0.002 side to side during the motion. Less than perfect.
As far as materials go, I picked four types of plastic that seemed right for the application. Two were Delrin, which is a brand name for Acetal Homopolymer (as opposed to Copolymer, which has reduced mechanical properties). One was a high grade PET material, and the last was Molybdenum Disulfide filled Nylon 6,6 (MDS Nylon, TECAMID).
All of them machined decently on the lathe, but they were all very stringy. I picked these four plastics primarily for wear resistance, operating temperature, stiffness, and creep resistance. Creep means that the plastic will bend over time if a pressure is constantly applied to it.
So far I have only tested the MDS nylon rollers on the linear carriages. Over the course of a day or so, they developed dimples from creep where the tapered surface rolls on the T slot rail. So MDS nylon is ruled out as a possible roller material. Black and white Delrin should perform the same; I'm unsure about the PET. Black Delrin is what SeeMeCNC uses on their Cheapskates.
I also considered using PEI rod for this, but it is significantly more expensive and I'm unsure about the wear properties. I'll give more updates on this when I make more progress this coming weekend. I bought more black Delrin rods because I'm going to have to make more of these rollers. I might also change the roller length and the tapered part that rolls on the T slot rail. I'll probably shorten the rollers and put fillets on the rolling surface that match the profile of the T slot extrusions. This will hopefully get more line contact area to prevent creep, and switching from MDS Nylon to Delrin should help too.
Pictures first!
