Volcano Test Print
Posted: Sun Jun 07, 2015 11:33 am
by gestalt73
Ok, this E3D Volcano hotend is kinda awesome.
I picked one up to see if I can print frame pieces with acceptable quality in less time.
150mm high model
239.82 cm3 of material
6.5 hours print time
To print this with my V6 with similar strength would be at least 22 hours.
Printed in Inland/ToybuilderLabs/PrototypeSupply White PLA
1mm nozzle, 0.5mm layers
Speeds 20mm/s perimeter, 40mm/s loops, solid, infill
1 perimeter, 2 layers skin, 25% infill
http://i.imgur.com/21nPRUK.jpg
[img]
http://i.imgur.com/21nPRUK.jpg[/img]
Re: Volcano Test Print
Posted: Sun Jun 07, 2015 4:02 pm
by Tincho85
I want a close-up of that beauty!
Posted: Sun Jun 07, 2015 4:23 pm
by gestalt73
No problem, just click on the link above the photo, should bring you to a full screen shot.
Posted: Sun Jun 07, 2015 4:28 pm
by Tincho85
Missed it
Thanks.
Did you have to increase the temperature to use the volcano?
Posted: Sun Jun 07, 2015 5:19 pm
by gestalt73
Almost all of my previous work was done in ABS, so I'm still getting used to PLA as well as the Volcano, trying to find the optimal settings.
This print was completed with the following settings:
- 60c bed temp
- 230c first layer temp
- 220c layer temp
As time permits, I'll experiment more with the print temps, to see how low I can go before I have delamination issues with the print.
But for now, all of my PLA prints have been at 220c, and are very sturdy.
I've also had limited success printing directly on the glass, but this print had elmer's purple glue stick on the bed just to be safe.
Posted: Mon Jun 08, 2015 6:49 pm
by jesse
I bought the clone volcano kit on aliexpress. I'll post a review once it's setup.
Posted: Mon Jun 08, 2015 7:10 pm
by Mac The Knife
jesse wrote:I bought the COUNTERFEIT volcano kit on aliexpress. I'll post a review once it's setup.
There, fixed it for you.
Posted: Mon Jun 08, 2015 8:19 pm
by bot
I don't see how it is counterfeit if it is open-source to begin with... lol. You're counterfeit!
[edit] oh, nevermind... e3d products are misleadingly "open source." They have the ridiculous "no commercial" tag on the drawings. What a fucking joke. Maybe I won't be so enthusiastic about e3d hotends going forward...
Posted: Mon Jun 08, 2015 9:02 pm
by Mac The Knife
If it was an exact copy of the e3d hotend, then it would be a "clone", But since it's aliexpress I'd bet its machined poorly, with questionable materials. "counterfeit".
Posted: Tue Jun 09, 2015 7:13 am
by jesse
I'll let you know if it's adequate or not.
Posted: Tue Jun 09, 2015 4:42 pm
by bot
Ohh I get what you're saying. I would like to know as well how the Machining on that part turns out, and which seller you got it from. A lot of people lump all manufacturers in China together, which is kind of ridiculous, because there are like ten thousand different large machine shops in china.
Posted: Fri Jun 12, 2015 6:07 pm
by Sonrisa3D
been having really great results with mine also - loving the volcano.
DG
Posted: Sun Jul 26, 2015 8:19 pm
by jesse
I'm loving it too. I installed the Volcano clone upgrade this weekend. You can pretty much double the max print speed of an e3d v6. If only I could get a 0.2mm or 0.3mm nozzle then I wouldn't have to go back for detailed prints.
Volcano clone (compatible with E3D v6)
http://www.aliexpress.com/item/E3D-Full ... 51056.html
Volcano nozzles (including 0.4mm)
http://www.aliexpress.com/item/5Pcs-Lot ... 53842.html
Posted: Fri Aug 07, 2015 7:11 pm
by drwho
Wow this printed very well. Have been working with ABS primarily on a Volcano 0.8mm and decided to try 1.2 in PLA. The results have been less than good. Im sure it has to do with the fact that I switch two variables at once.
I would be interested in see your settings. Or a config file added here would be cool too.
Keep printing the future.
Posted: Fri Aug 07, 2015 8:19 pm
by bubbasnow
i did these e-chain links with volcano 1.2mm nozzle 1mm height. PLA. 230deg 45mm/sec
what would have cost me a couple hundred, i did with 4lbs of pla
did it all in a weekend
[img]
https://lh3.googleusercontent.com/Do25d ... 37-h246-no[/img]
[img]
https://lh3.googleusercontent.com/fBn-7 ... 40-h922-no[/img]
[img]
https://lh3.googleusercontent.com/lDJW2 ... 19-h922-no[/img]
Posted: Mon Jan 04, 2016 5:55 pm
by drwho
bubbasnow wrote:i did these e-chain links with volcano 1.2mm nozzle 1mm height. PLA. 230deg 45mm/sec
Have become more proficient in PLA on both a .4mm and .8mm tips and I will be trying these settings on the 1.2mm later tonight. Thank you for sharing.
Posted: Wed Jan 06, 2016 11:54 am
gestalt73 wrote:Ok, this E3D Volcano hotend is kinda awesome.
150mm high model
[img]
In the closeup view it is difficult to see the layer lines, a very good job!
Posted: Wed Jan 06, 2016 11:57 am
They look great to me, Last time I tried to do a cable chain I threw it in my plastic recovery box.
A very nice job!
