print size changes with nozzle size.
Posted: Tue Jun 09, 2015 10:44 am
so I have been working with a .7mm nozzle for a few days. I printed a couple of parts yesterday and last night that I had recently printed with a .5 nozzle. same STL file, same Slicer (matter control) the only difference is the nozzle size. the prints are coming out larger by a few thousands. for instance with the .5 nozzle I had to adjust in the drawing the diameter of a hole that was made for a roller bearing to sit inside. I had it dialed in perfectly with the .5 nozzle, a nice interference fit. using this same drawing the bearing hole is now too large by the amount I adjusted it, which is 10 thousands.
on another part the edge to edge diameter has changed. it is a hexagonal shape and flat to flat it is about 20 thousands bigger, just enough that I cannot mate the part with the older hexagonal shape printed with the .5 nozzle.
by changing part diameter and sizes I thought I was just correcting for thermal expansion and other oddities caused by making a part with quickly solidifying plastic. I did expect a bit of a change but not one of this magnitude.
has anyone else run into this issue? I.E. having to change part dimensions when a nozzle size is changed?
Tom C
Tom C
