Trouble calibrating and weird noises
Posted: Mon Jun 22, 2015 10:57 pm
I am the owner of a newly constructed Rostock Max v2. I'm in the process of calibrating my towers. I first manually adjusted my Z height, and I'm now trying to run the macros to get the bed level.
The first thing I noticed is that the stepper motor on the Y tower is really loud when running the macro. All three motors are quiet when I home them or manually move them in the x, y, or z directions, but the Y tower is making a pretty loud noise when running any of the macros. I don't think it was put onto the machine any differently from the others. They were all mounted using a caliper to measure an offset for the motor dampeners that I bought from Astroboy. They were all then screwed on using the blue thread locker.
Any ideas what could be causing one tower to make more noise than the others? Does belt tightness effect this?
Even with the noise, I tried to run the setup for the z tower. I tried adjusting the screw, but even with the screw backed out to the point of being wobbly (lowering the bed), the hot end would end up pinning the paper to the glass. I then tightened the screw back to the starting position and tried substituting 1 for the 0 in the macro for the z value (usually it is "G0 Z0 X0 Y90 F3500" but I put "G0 Z1 X0 Y90 F3500"). This was almost perfect, but i have no idea how to use that information.
I don't understand gcode. Does this number represent a height measurement? If so, what is the unit? Does this indicate that my towers aren't straight? The framing square I used when building my rostock is pretty crappy, so this is my biggest concern.
Just to see if the other towers were in the same boat, I ran the other two macros. The Y tower pinned the paper pretty hard, and the X tower actually felt pretty close to right the first time.
