leakage
Posted: Mon Jun 29, 2015 9:24 am
by JFettig
What does it take to make a leak-free print? Its funny, about 2" up it doesn't leak. It leaks through the bottom and sides, each side is solid 6 extrusion widths thick. ESUN PETG printed at 260C with .4mm nozzle.
[img]http://i.imgur.com/E841C2D.jpg[/img]
It doesn't appear to be leaking anywhere near start/stop ends, which have over extrusion due to my settings.
Re: leakage
Posted: Wed Jul 01, 2015 11:34 am
by RocketMagnet
Try ABS and then Propanone (Acetone) Vapour... that would form a water tight part...
Not sure what you could replace the Propanone with for PETG as most chemicals it's soluable in probably aren't available to the general public.. (possibly Toluene? at a guess but really not sure and depends on your country if you can get hold of it)?
Probably much easier to simply go ABS + Propanone IMO.
Re: leakage
Posted: Wed Jul 01, 2015 3:43 pm
by bot
Weird, I printed a thing that wasn't even intended to be water-tight and it is. It held water for days without even a drop coming out. It was a round bowl-like shape, though. Perhaps try giving a gradual curve to the shape, so that there are no 90 degree corners. Then each layer is slightly offset from the others, filling in voids?
Re: leakage
Posted: Fri Jul 03, 2015 7:22 am
by RocketMagnet
Wall thickness will be a big factor and even the way you slice the file can result in tiny gaps and holes dependant on tool path.
Personally I've found thin cylinders to be the hardest to get water tight right from the printer and trying different slicers/settings can produce better results based on the part.. but none are simply the best at all parts.. trial and error imo....
Any cracking caused by shrinkage will generally lead to failure.. so considering the above it's why it normally simpler to solvent vapour seal items you want water tight...
Re: leakage
Posted: Fri Jul 03, 2015 10:09 pm
by bubbasnow
ive actually had really good luck with single layers using the volcano 1.2mm end. water tight vases for days!!
Re: leakage
Posted: Fri Jul 03, 2015 11:53 pm
by JFettig
I have been tempted to get a volcano nozzle for my E3D, it would probably take care of the problem.
I think that if I pre-heated the enclosure for a couple hours prior to printing, it would have all sealed up, the first 2" is all that leaked, I theorize that the enclosure was quite toasty by the time it got that high up and it helped inter-layer bonding.
Re: leakage
Posted: Sun Jul 05, 2015 12:42 pm
by teoman
What is the application? Cosmetically important or not?
Re: leakage
Posted: Sun Jul 05, 2015 1:19 pm
by JFettig
Sub Irrigated planter - so yes, important.
Re: leakage
Posted: Sun Jul 05, 2015 1:40 pm
by teoman
Any reason why ABS would not work? As you could acetone polish it.
