Page 1 of 2
Pulled the Pin...
Posted: Mon Jun 29, 2015 11:41 pm
by ZakRabbit
Very similar to Aflac, I just placed my order with Brian at TrickLaser today; frame, arms, max plate, Flyin' Strude, Trick Trucks, all the way through to the Prometheus, also included my order with Open Builds filling in the Trick Trucks, belts, switches, etc...
So far, the plan is for .9 steppers, I'm still debating on the electronics: it seems Smootieboard is the way to go any thoughts as to whether Azteeg has a little edge over the "standard" Smoothie? I know this is highly irregular and highly ill advised, but this is my first build and I'll just take it slow, ask a lot of questions, and keep everybody up on my failures until I get it right! Thank you all for your support, your guides and your patience! Pics will be posted as it all comes in!
Zak
Re: Pulled the Pin...
Posted: Tue Jun 30, 2015 1:49 am
by Aflac
Guess we had similar ideas. I've had a lot of internal debate on the electronics as well. But I ended up deciding on the smoothie, mostly due to 626pilots auto calibration stuff and what I've seen on the next gen smoothie stuff....ideally I would wait for that, but who is patient enough for that.
Posted: Tue Jun 30, 2015 11:51 am
by ZakRabbit
Hey, great minds, right? I was just wondering straight smoothie or does the Azteeg do anything "better?" I say this now, and I'm sure it'll change, but not planning on multiple hot ends or anything, I'm just looking for accuracy as we'll be printing prototype fitment parts.
Posted: Tue Jun 30, 2015 5:13 pm
by forrie
Def get a Smoothie over the Azteeg.
Posted: Tue Jun 30, 2015 6:43 pm
by Mac The Knife
forrie wrote:Def get a Smoothie over the Azteeg.
Why??
Posted: Tue Jun 30, 2015 9:30 pm
by ZakRabbit
Mac The Knife wrote:forrie wrote:Def get a Smoothie over the Azteeg.
Why??
The more research I do, the more I find the Azteeg seems to have some reliability issues.
Posted: Tue Jun 30, 2015 9:33 pm
by ZakRabbit
Just ordered three .9 motors and one 5:1 geared unit for the extruder. Been reading way too much mhackney...
Posted: Wed Jul 01, 2015 9:05 am
ZakRabbit wrote:Just ordered three .9 motors and one 5:1 geared unit for the extruder. Been reading way too much mhackney...
Which motors did you order?
Posted: Wed Jul 01, 2015 12:27 pm
by ZakRabbit
Jimustanguitar wrote:ZakRabbit wrote:Just ordered three .9 motors and one 5:1 geared unit for the extruder. Been reading way too much mhackney...
Are we allowed to give the website name? I don't want to step on any toes, but here are the p/n's:
3 x 0.9deg Nema 17 Bipolar Stepper Motor 2A 46Ncm 17HM19-2004S
(17HM19-2004S) = US$ 40.35
1 x Gear Ratio 5:1 Planetary Gearbox With Nema 17 Bipolar Stepper
17HS15-1684S-PG5 (17HS15-1684S-PG5) = US$ 29.10
And, of course, I ordered a FSR kit before finishing 626pilot's thread, so I'm not sure what I'm going to do as far as a probe for calibration. I'm thinking of how to spring-mount the Prometheus so that it's sturdy enough to print with yet will move when I want to probe without breaking the glass or denting the PEI.
Posted: Wed Jul 01, 2015 5:31 pm
by forrie
ZakRabbit wrote:Mac The Knife wrote:forrie wrote:Def get a Smoothie over the Azteeg.
Why??
That's why...
Posted: Wed Jul 01, 2015 5:55 pm
by ZakRabbit
I'm guessing that I need the X4 at a minimum, yes? I know I say this now, but I'm not planning on multi-head/multi-color stuff, I just want something that's accurate.
Posted: Wed Jul 01, 2015 9:49 pm
by ramai
following along
Posted: Wed Jul 01, 2015 10:50 pm
by Aflac
ZakRabbit wrote:I'm guessing that I need the X4 at a minimum, yes? I know I say this now, but I'm not planning on multi-head/multi-color stuff, I just want something that's accurate.
I'm planning on the x5 just in case I want to upgrade later.....and I have an irrational need to have the best
Posted: Thu Jul 02, 2015 12:40 am
by ZakRabbit
Aflac wrote:ZakRabbit wrote:I'm guessing that I need the X4 at a minimum, yes? I know I say this now, but I'm not planning on multi-head/multi-color stuff, I just want something that's accurate.
Totally understand! I'm thinking of going with the onboard regulator as I'm not going to have a separate lcd or anything, it'll be plugged into a desktop at all times.
Posted: Sat Jul 04, 2015 1:42 am
by ZakRabbit
Moving right along, I HAD to buy something from SeeMeCNC, so I ordered the heated bed, boro glass plate, and an EZ-struder... I think I've decided on the Smoothie X4, now it's down to power supply. Pollygonhell was great in another thread, and with his advice I think I'm going to go with a LED PSU, possibly two: a 12V for the board, hot end, steppers, and, a 24V for the bed.
Edit: just ordered the PEI print surface, two sheets of the 12 X 12, and bought a six-pack of the 12 x 12 3M adhesive so if anyone is about to do this, let me know I'd love to share whatever extra sheets I have to further the cause.
Posted: Sat Jul 04, 2015 4:00 pm
by ZakRabbit
Quick question, is some sort of LCD screen considered a necessity, or something that's nice to have? I'm facing building the machine here at home, probably setting it up here using Linux but actually running it at work on a Windows machine. Any opinions?
Posted: Sat Jul 04, 2015 4:06 pm
by Tincho85
You will miss Z calibration and SD card.
But yea, you can use it without the LCD screen.
Posted: Sat Jul 04, 2015 4:16 pm
by ZakRabbit
Tincho85 wrote:You will miss Z calibration and SD card.
Does losing the Z calibration still hold true when using 626pilot's smoothieware? I have an FSR kit coming, and will be using the X4 board. Thank you all for your input!
Posted: Sat Jul 04, 2015 6:43 pm
by forrie
Get the GLCD, mounting pcb, and a couple of 1A voltage regulators from robotseed. It makes setting Z a whole heap easier.
Posted: Sat Jul 04, 2015 8:24 pm
by ZakRabbit
forrie wrote:Get the GLCD, mounting pcb, and a couple of 1A voltage regulators from robotseed. It makes setting Z a whole heap easier.
I'll have to do that, then, thank you! I know Uberclock offers the 1 1A regulator, is there a place for a second on the smoothieboard? As I'm in the 'States, I don't know if I'm "allowed" to buy from robotseed, and Uberclock is currently out of their glcd's, are there any alternatives that can be recommended? Viki V2, possibly?
Posted: Sat Jul 04, 2015 9:15 pm
by forrie
Yep...Solder one on the pcb and one on the smoothie.
Posted: Sat Jul 04, 2015 9:39 pm
by ZakRabbit
forrie wrote:Yep...Solder one on the pcb and one on the smoothie.
pcb of the shield adapter?
Posted: Sat Jul 04, 2015 9:49 pm
by forrie
Posted: Sat Jul 04, 2015 10:00 pm
by ZakRabbit
Posted: Sun Jul 05, 2015 12:21 am
by ZakRabbit
Just placed the order with robotseed for the 5x, the sheild/glcd "kit", and two of the 1A regulators. Jumped the gun at reprapdiscount for a single GLCD display so I'll have one for sale once it arrives. Getting closer. Just gotta get the PSU(s) and I'll have all the parts ordered...
