Inconsistency in calibration (Z-height)
Posted: Thu Jul 02, 2015 4:48 pm
The issue is hard to explain so please bear with me....
I recently finished my v2 (first printer build) and the calibration was going well until it came to playing with the Z-axis.
Basically, the problem arises when using the "ALL" Movement Controls on MatterControl and when I press "Home Towers" on the printer. Sometimes when I select "ALL", the cheapskates do not rise fully to the top. That's not the main issue, however. 95% of the time, the three skates will go to the top, two of them will hit the end switch (always X-axis and another) and either Y or Z will barely miss it. This causes one of the motors to keep running - if Y doesn't hit the switch, Z keeps going. As a result, the motor skips across the belt and makes a loud grinding sound and also messes up the Z=0 value.
Twice, I have successfully made it past this point to where I'm setting my macros but then the commands (manually entered, not macros) mess it up again.
I have tried changing the tension of the cheapskates, adjusting the height of the end stop screws, and making sure that the skates all start from the same position.
Any help would be much appreciated...thank you
