Re-calibrating - can't get Horizontal Radius to touch paper?
Posted: Fri Jul 10, 2015 12:00 pm
Just came back to redo my horizontal radius as I noticed printing wide prints it was arching and the center was too high, and the outsides too low.
I was at 129.5 for my Horizontal Radius when I originally calibrated the printer, so I went back to the manual to get the right steps to know what to do.
So I have done this in the following order:
* Set Z=0 with paper
* Z-Tower Adjust macro and adjusted endstop as required
* Y-Tower Adjust macro and adjusted endstop as required
* X-Tower Adjust macro and adjusted endstop as required
* Bed Center - paper is not being grabbed at all, increased 0.5
* This was a familiar pattern so I started going in higher increments from 1's, to 2's, to 5's - up to 150mm - still the Bed Center macro has 0 change in how high it is - it is STILL not grabbing the paper :S
Am I calibrating it wrong? It seems I must be for the height to not change at Bed Center?
Should I maybe doing it in this order?
* Repeat above.
I validated all my macros are correct, so not sure what I'm doing wrong?
Any help much appreciated.
* Repeat above.
