Did I blow up my RAMBo?
Posted: Wed Jul 29, 2015 10:38 pm
				I built a ghetto enclosure for printing a large ABS print on my Rostock v1.
It was simply a cardboard tube that surrounded the whole machine including the base. It had plenty of rooms for the arms and it maintained an internal temp between 37-40º with the bed at 110º.
Everything seemed to run fine and the print stuck great however here's what's happens now:
- Bed doesn't seem to stop heating after it reaches temp. It keeps climbing (not sure the limit) and will only start cooling when I turn off the bed in Repetier. Even though the bed light is NOT lit and it's showing no power to the bed in Repetier.
- Extruder seems to over-extrude now. Not sure by how much but probably 150% more filament. Before I figured out something was wrong I was running a filament at 0.75 extrusion rate and it was still far too much.
Fuses are all fine.
No obvious melted wiring
Underside of bed looks fine, no melted wires
Fuses are all fine.
  I knew it was a winner as soon as I saw it. Props to nitewatchman for eloquently capturing how we all feel about our machine sometimes!
