Hot End stepper motor not feeding plastic
Posted: Fri Jul 31, 2015 3:21 pm
by Potatohead908
I am still in the process of setting up my MAX V2. Everything has worked as it should to this point in the instructions up to this point. I can move the stepper by hand with the power on so I'm thinking it doesn't have power. This could be a wiring issue or a fuse issue. I will look into the wiring tonight when I get home. Is there any other things I should look at? Again everything else has worked up to this point in the instructions. I have calibrated the axis and am almost ready to start printing.
Re: Hot End stepper motor not feeding plastic
Posted: Sat Aug 01, 2015 2:39 am
by Potatohead908
Simple fix. I skipped two sockets instead of one when I connected the stepper to the board. Ooops!
Posted: Sat Aug 01, 2015 10:22 am
Potatohead908 wrote:Simple fix. I skipped two sockets instead of one when I connected the stepper to the board. Ooops!
Hey, at least you got it fixed!
Posted: Sun Aug 02, 2015 2:53 pm
by Potatohead908
Yes!! It is now officially ALIVE and COMPLETE!! The first thing my oldest son asked me to print was too big!! Go figure!
