Whenever I flash over repetier my printer gets stuck in a weird boot loop. it'll start up then attempt to home the towers then estop and reboot.
Any help is appreciated
https://www.youtube.com/watch?v=GQZlVIxgPlc
						Stuck in a boot loop
Re: Stuck in a boot loop
I had that happen to me when the reset button on the front panel got stuck.  The plexiglass tab over the button was catching, and keeping the button pressed on the RamBo.
also check your LCD cables, if the ribbon cables are put on wrong it can cause the printer to keep rebooting as you are describing.
I had to flip my lcd "B" cable, thanks for the help
