Definition of insanity
timothysvec
Post by timothysvec »
Greetings: Some say the definition of insanity is; doing the same thing over and over, thinking somehow, the outcome will will be different. I like doing that and have even provided a picture to prove it. :D Anyway, could someone out there in forum land lend me a hand. I squared everything, leveled the bed, slowed everything down, am using seeme cnc profile (yoda) and slicer. did belt tension. am running 180F on hotbed and 420F on hot end. 1/8 step with 4 axis mach 3 old pc putting out solid 5 volts. Hmmmmmm what could i be doing wrong? cheers, tim
[img]http://i48.tinypic.com/2a5g0f5.jpg[/img]
[img]http://i46.tinypic.com/1zy79x.jpg[/img]
tom10122
Re: Definition of insanity
Post by tom10122 »
I'm in the same boat, I had one print out good then i redid my hotend and its f'ed up too, did you do the belt tension mod?
timothysvec
Yes on x axis with hose clamp.
drew
Post by drew »
Did you do the optoisolator mode on the 4 axis board? If not try that.
kilroyo
Post by kilroyo »
I had the same issue ,and could never find the solution until I changed the computer. I had mach3 on an old computer and once I changed the computer the slant went away..
timothysvec
Thank's guy's. The optoisolator mod made a big improvement!
[img]http://i50.tinypic.com/2rolvgp.jpg[/img]
