Max Metal Aluminum Bed Mount Including FSR Mounts
Posted: Tue Aug 18, 2015 5:34 pm
by ZakRabbit
This is what I came up with for mounting my bed to the Trick Laser Max Metal frame based on geometry provided by Brian. It includes pockets for FSR's. I'm making it out of aluminum, but if you're creative and cut it up, I'm sure it could be printed then glued.
Re: Max Metal Aluminum Bed Mount Including FSR Mounts
Posted: Wed Aug 19, 2015 7:22 am
by Renha
Thanks! i'll check it later
EDIT: strange dimensions in STL
Posted: Wed Aug 19, 2015 10:34 am
by ZakRabbit
Renha wrote:Thanks! i'll check it later
Sorry, it is in inches. If I can fix anything, please let me know.
Posted: Thu Aug 20, 2015 12:45 pm
by bvandiepenbos
Netfabb can scale inch parts to MM
(simply scales it up 25.4)
probably could do the same in Repetier, Matter Control or whatever slicer you use.
although I think netfabb does a better job re-sizing.
I *ALWAYS* run my parts through netfabb before slicing, to fix any issues and to verify size.
