Extrusion FAIL!
Posted: Sat Aug 22, 2015 8:55 pm
by REV
I had just put on some trick laser arms, and done a few great prints with them. I've had an E3D sitting around too, that I've never hooked up because I've never had a single problem with the stock hotend.
until now
major bummer, because I'm in the middle of fulfilling some orders for 3D hubs. This started as an adhesion problem, I had run out of gluestick and had just re-wet what little there was on the caption tape. shoulda run out to the pharmacy and bought some more glue. Instead I went for a 35 mile bike ride...
Looks like I'll be installing that e3D tomorrow... btw, any good tutorials out there for this?
this is my first major fail, and I feel like I've hit some sort of milestone or something...
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 9:51 am
There's nothing fatal going on there. Just remove the layer fans and heat up the hot end. You should be able to pull the blob of plastic off quite easily.
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 11:55 am
by REV
geneb wrote:There's nothing fatal going on there. Just remove the layer fans and heat up the hot end. You should be able to pull the blob of plastic off quite easily.
Ok, I will try that. however, it mushroomed out the top too, creating a sort of big plastic rivet.
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 4:20 pm
by REV
here is another pic. fixable?
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 4:47 pm
by REV
This is not fixable. I tried heating it up, prying it off, not happening.
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 6:30 pm
That's...impressive. :D
I'd almost be tempted to frame that. :)
It's not a total loss though - you should be able to disassemble the hot end (top section, peek, heater block) and using needle nosed pliers and wire cutters, get it free from the block of plastic. You'll of course need to replace the resistors & thermistor, but that's pretty simple.
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 6:39 pm
by Eric
Even if you decide to replace the hot end, you still want to save the effector if you can. If you remove the arms from the effector as well as any other disassembly possible you will have greater access with tools. A hot knife (I have knife blade for one of my soldering irons) may help...but dont let it touch the effector itself.
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 8:31 pm
by McSlappy
That's a world class fail there. I'd just get a new hot-end and keep that on the wall. Yes you could recover it, but it's art now!
Re: Extrusion FAIL!
Posted: Sun Aug 23, 2015 8:57 pm
by Mac The Knife
What material were you printing with? I did this with trimmer line (nylon) and cleaned it up. It did take a few hours, and a dremel, and a car battery.
Re: Extrusion FAIL!
Posted: Mon Aug 24, 2015 11:04 am
by REV
Hot knife- yes.
This is PLA. It was really stupid of me to leave the printer knowing full well that the bed adhesion was sub optimal. Now I've a good excuse to rig up the E3D tho! I was hoping to print a mount for the e3D. or can I theoretically reuse this one if I can free it that is?
I gotta say, 1300M of equal parts ABS and PLA, not a single jam with this stock hotend. That why my e3d has been sitting around for so long! I figured I'd set it up once I had a good reason... and I guess this is it. But it is not the fault of the stock hot end. ...user error :|
Wait, a car battery?
Re: Extrusion FAIL!
Posted: Mon Aug 24, 2015 2:42 pm
by REV
This is a question I've been searching for and is related enough i think...is there a way to mount the e3D to my existing all stock effector without having to 3D print anything?
Re: Extrusion FAIL!
Posted: Mon Aug 24, 2015 4:26 pm
by REV
Ok, well I got it taken apart, and the effector platform is still intact. Now, how to mount the e3D...
Re: Extrusion FAIL!
Posted: Mon Aug 24, 2015 8:09 pm
Man, that's just epic. I'd have to frame it. :)
Re: Extrusion FAIL!
Posted: Fri Sep 04, 2015 1:30 am
by Agisis
Could you stick it in your oven at 450 degrees? That should be low enough to not melt the stock hot end, but heat up the part to remove the filament. Just a thought. I agree though, that is massively impressive and I feel terrible for ya.
Re: Extrusion FAIL!
Posted: Fri Sep 04, 2015 7:51 am
by Jimustanguitar
Put it in a tupperware with a few caps full of the non acetone nail polish remover. It makes PLA gummy (wait 2 days or so), and it might be enough to give you some flex and help you get it off of there.
I agree with Gene. It's modern art :)
Re: Extrusion FAIL!
Posted: Wed Jan 06, 2016 7:47 am
by johnoly99
Frame that thing! That's art! We have a few like that around the shop that customers have sent or brought us in, and i believe PartDaddy himself has one hiding somewhere. It is a milestone, for sure. Glad to hear the original lasted a good long time for you.
Re: Extrusion FAIL!
Posted: Wed Jan 06, 2016 8:38 pm
by Outsider
EPIC.... truly EPIC.... It's a MASTERPIECE!!!
Sometimes you earn a real trophy the hard way.
