What are the filament specifications?
Posted: Tue Sep 01, 2015 8:29 am
by hcdbey
Never printed before. I would like to know if there are specifications for filament I can quote to ensure I get good filament or is it simply a matter or buying from a trusted supplier?
Also, can anyone recommend an ABS filament supplier in Paris, France?
Re: What are the filament specifications?
Posted: Tue Sep 01, 2015 9:13 am
If you're in Europe, check out Colorfabb.
The specs and chemistry vary considerably between manufacturers, and most if it is undocumented/unconfirmed so your best bet is to find a supplier that you trust.
Posted: Wed Sep 02, 2015 4:20 pm
by hcdbey
Thanks. I am in Africa but Europe is probably my nearest best bet for colorFabb filament. I will give them a try.
Hank
Posted: Wed Sep 02, 2015 5:26 pm
by teoman
You want the 1.75mm stuff.
ABS or PLA is up to you.
