Adapter plates for EZStruder with Geared Nema17
Posted: Wed Sep 02, 2015 1:07 pm
I am making a small batch of these adapter plates to use the Kysan 5:1 gearmotor or others with the EZStruder. I'll be asking $23 shipped(lower 48 states) for each, qty discounts(10+) available
I take Paypal or Money order.
They use the Hobbed gear from Tridprinting and they also have a geared Kysan. Same motor is available from other retailers and other geared nema17 motors are also available.
[img]http://i.imgur.com/hE4gMdi.jpg[/img]
Setup is easy, attach hobbed gear and measure 1/8" from the end of the shaft to the end of the gear(note orientation), tighten down
[img]http://i.imgur.com/ITZDPcG.jpg[/img]
Attach adapter plate with supplied screws;
[img]http://i.imgur.com/PowKU74.jpg[/img]
Attach bottom half of EZStruder:
[img]http://i.imgur.com/ormPHgP.jpg[/img]
Attach top half of EZStruder:
[img]http://i.imgur.com/WBdJtDr.jpg[/img]
Then re-attach to your printer! Don't forget to modify current settings for the motor as needed. I haven't installed mine yet but will report back.
Note gear location to drive roller. Ok to install top half before bottom half
[img]http://i.imgur.com/ehKSAGe.jpg[/img]
Hobbed gear: http://www.tridprinting.com/Mechanical- ... Drive-Gear
Geared Kysan: http://www.tridprinting.com/Electronics/
10/15/15 - I have 7 in stock, have a run on the schedule.
[img]http://i.imgur.com/pVxSAc6.jpg?1[/img]
