Torture Test in pla
Posted: Thu Sep 03, 2015 2:16 pm
Hello All-
I've beed doing some 'torture tests' with PLA in the interest of improving print quality after installing trick laser arms and an e3dv6. I'd like to minimize the blobbing or warts, the stringing, and the inconsistent layer lines seen in the photo below lit chiaroscuro to exaggerate imperfections:
the print on the top represents my first attempt (after making the e3d and PLA play nice), using these settings: The print on the bottom, after going through a number of iterations, is the result of these settings: If anything stringing has gotten worse, blobbing has too albeit incrementally. Layer line variance is the same. Stringing may be a result of coast setting? I think for the next print I'll turn that off, and also add a little extra restart distance. I'd be curious about what you guys have to say. Should I ditch the torture test and just start with a 20 mm calibration cube?
What is the effective difference on print quality between filament diameter, extrusion multiplier, and extrusion width? Or are they all just different means to the same end? i.e. mm/s of filament. After measuring the filament in 10 places with calipers and averaging to arrive at filament diameter I then started to tweak the other numbers because I felt that the inconsistent layer lines were a result of over extrusion. And that the blobs are to some extent a result of too much back pressure in the nozzle. Both of these problems being somewhat related...
-Rev
-Rev
