MAD AS HE**!!!
Posted: Fri Oct 05, 2012 12:57 pm
So I've been gone a long time for work and I am finally getting some time to play with my H-1 again, but I have a very odd problem that I can't shake. One day I was printing just fine (other than some minor quality issues) when I had to stop my printing and start over because of a problem with my STL file (I drew a large cantilever that would have needed support material...). When I restarted the print some time later that evening, the extruder was pushing out close to 10x the required material. I would bet that my extruded bead averaged 4mm width and the gcode seemed to be to blame. I later talked to John and verified that my steps were correct, but we never really discussed the gcode issues. First, the gcode would call for a 1mm retraction, but the extruder stepper would retract the filament all the way out of the extruder and then some. I tried to dial it all in by reducing my steps in Mach, but it really made no difference. I've tried a time or two since I talked to John in May and I was working with Lynx a very little bit at one time also (he sent me some files to slice and I sent him the gcode and that's the last I heard from him...).
Anyone have ideas on this? I have a prototype to send off 6 months ago. I'm wondering about the easydriver. It seems like it's multiplting the output but I am not sure. I did the opto mod on the 3 axis driver and I have tried slicing and printing from different computers also.
Help is sincerely appreciated and if new electronics (above and beyond the easydriver) are the answer I need to bail on this. I just can't afford to throw more cash at this thing and then spend all my free time trying to configure it again.
I can send anything you need as needed and I can slice STLs for your comparison also just let me know.
Gabe
Gabe
