New build - first 3d printer! PID Calibration errors - help!
Posted: Sun Sep 20, 2015 11:33 pm
Hi Everyone!
Well, it's been a fun journey building the printer up till now - it's finished and everything went smoothly.. the only things that I would suggest regarding the manual is to clarify the position of the tower bearing idler towers - as the manual is ambiguous about what direction they should be placed (it turns out I dismantled the correct way and did it the opposite - but I just reversed the stepper for the extruder and all is fine) - and also to clarify how much wire to pull from the start.
Other than those two things - it fires up and talks to the PC, just waiting for my filament to arrive now!
One issue that I had was the PID calibration - I received the PID autotune failed! Temperature too high error.
I'm hoping someone can help me out and let me know if what I've done is correct (and if it will have any negative consequences?):
I reduced the PID drive max to 128 as per the manual - same error.
After a load of research, I tried:
Reducing PID_MAX in configuration.h on Arduino to 25 (from 255), dropped the PID drive max to 90, and tried a combination of m303, m303 s200, m303 s150, m303 s200 e8 and finally got it going by blowing a fan on the hot end for about 5 seconds as it reached 219 degrees, which luckily brought me back into spec and completed the PID calibration.
I've then calculated the averages for the values and entered them into the EEPROM,returned the configuration.h to normal, and returned PID drive max in EEPROM to 205. Saved, and tried to get a stable temperature while I went on to calibrate the tower heights.
My troubleshooting also caused me to think I had too much Kapton around the hot end, so I've removed a lot of it including the single wrap around the barrel on the extruder.
So far, all seems good - when heating to a set temp of 200, it spikes to 210, then to 195, then 203, 199 and then stabilises within a degree of 200 and stays there. I haven't run any filament through it yet though..
Will this have caused any problems? Is there any explanation as to why the heater is going so crazy that even with PID Drive on 128 PID autotune fails?
FYI, I'm living in Bangkok, so the ambient temperature even in aircon sits around 30 degrees celsius
[edit - I should have mentioned - it's a Rostock Max v2
Thanks in advance,
Ben
Thanks in advance,
Ben
