				Rostock Max V2 goes to DEF DEF when bed is above 90C
				Posted: Tue Sep 22, 2015 7:12 pm
				by TFMike
				I normally print around 70-80C bed temperature, but without an enclosure, printing with ABS needs a bit hotter bed temp. So I had been experimenting the last few days with temps at and above 100C, but I noticed something extremeley strange - halfway through the print the lcd screen will read DEF for both the hotend and the bed. Its not the hotend because when I flip the on/off switch quickly the temp readings return.
So the only thing I can think of is that I made an error when I installed the thermistor and heating resistor to the heated bed, but what could it be and how do I fix it/troubleshoot it?
Any help is appreciated, thanks.
				Re: Rostock Max V2 goes to DEF DEF when bed is above 90C
				Posted: Wed Sep 23, 2015 9:07 am
				"def" shows up when one or both of the thermistors are bad or disconnected.  When the "def" (defective) label appears, does it do it at the same nozzle height?
				Posted: Thu Sep 24, 2015 4:46 pm
				by TFMike
				I dunno, thats a good question actually. I have tightened the the conenction on the hotend thermistor and I can try to print something else and see if it happens again. Why would it short out at a certain height though and not another?
				Posted: Thu Sep 24, 2015 5:46 pm
				Might be a break in the wire that only separates when the wire is at a certain bend angle.
				Posted: Thu Sep 24, 2015 6:03 pm
				TFMike wrote:I normally print around 70-80C bed temperature, but without an enclosure, printing with ABS needs a bit hotter bed temp. So I had been experimenting the last few days with temps at and above 100C, but I noticed something extremeley strange - halfway through the print the lcd screen will read DEF for both the hotend and the bed. Its not the hotend because when I flip the on/off switch quickly the temp readings return.
Have you found and fixed the problem?
