bed leveling seems ok but not...what a nightmare
Posted: Fri Oct 09, 2015 2:07 pm
Hi all ! I've seen a lot of topics about the bed leveling problems and know i think it's time to add mine !
I'll try to be as clear as possible: everything was ok for my Max V2 since i got my printer (in june if i remember right). Mounting it was cool, the first calibration was hard but ok at least, and i've print about 1.5km of filament until last week.
I wanted to do a new calibration after having move the printer, just in case something moved. So i made it, everything looked ok until i start a new print (calibration test with a big circle).
THE HOTEND STARTS TOO HIGH FROM THE PRINT BED AND THEN GO LOWER AND LOWER UNTIL I PUSH AGAINST THE BED. AND THE GO BACK TOO HIGH !!
If i'm right, some people had this kind of issue.
Now i'll explain where i think the problem "comes from". When i launch my calibration macros, just when the carriages start to lower, something happens like missing steps or something blocking (maybe be mechanical issue).
The interesting point for me is that it happens only for the macros X, Y and Z towers ! When i go to the center of the bed: everything is ok.
I think that this little thing that happen turn the calibration "wrong", even if at the end i'm at the right height for each positions including the middle point. Then when i start to print something, it's like my bed has an angle of some degrees.
Please tell me that one of you has some magic trick to fix this !
I've spend 4 evening this week trying to fix this with a lot of test, and i'm out of ideas.
