Config help: Temps off by a few degrees, no extrusion
Posted: Tue Oct 27, 2015 1:42 am
by 626Pilot
1: What are you using for your thermistor values?
2: I can't get this thing to extrude on E0 no matter what I do. The wiring is fine, same stuff I was using with my Smoothieboard. There are no errors on the G-code console when I try to extrude. Any ideas? (EDIT: Putting T0 at the end of config.g solved the problem.)
Re: Config help: Temps off by a few degrees, no extrusion
Posted: Tue Oct 27, 2015 1:50 am
by bot
At the bottom of my config gcode file I have a "T0" command. Try putting that there. I think you said you've been sending that, but the tool needs to be selected first no matter what.
Posted: Tue Oct 27, 2015 1:54 am
by 626Pilot
That seems to have done it! Thanks. I guess setting Heater 1 active in the web interface isn't the same as sending T0.
Also, it shuts down the hot end half of the time due to a temperature read error. I reboot the board, and it reads the temp just fine. What the heck?
Edit: It's this line in config.g: M570 S180
Should be M570 S300 or something like that. It throws a code if the hot end "takes too long" to heat up. Cyclops hot ends take awhile.
Posted: Tue Oct 27, 2015 1:59 am
by bot
Hmm, are you running an e3d v6? I haven't had any thermistor temp errors, but I've noticed that the board will do a full reset when I accidentally discharge static onto the brass nozzle. It must be eitehr overloading the thermistor or hotend, but seems to do not damage (that I can detect yet) other than halting the print or whatever was happening while the thing reboots.
Edit to your edit: Ah yes! I haven't tried the cyclops/chimera yet. I'm excited to give it a go. My current delta prints amazingly flat so far, I might be able to pull off the chimera.
Posted: Tue Oct 27, 2015 9:51 am
by IMBoring25
It took me a bit to figure out why it was doing that with my v6. I've been setting a first stage heating temperature rather than going straight to the printing temperature, but adding M570 with an S parameter in seconds to the config.g will change the timeout.
