DerZaubererer's FSR Montage
derzaubererer
Post by derzaubererer »
Hey guys today i took the Challenge and installed my new FSR kit i got.
i started with buying metric screws
[img]http://i.imgur.com/YSpVJen.jpg[/img]
they were perfect i then drilled a hole with a m6 drill to make the nut fit tightly inside
Sensor facing side:
[img]http://i.imgur.com/KPVSpHD.jpg[/img]
Snowflake facing side:
[img]http://i.imgur.com/TrWscwZ.jpg[/img]
i then just screwed everything together with the 16mm long m3 Scews
[img]http://i.imgur.com/29038G1.jpg[/img]
<-- here you can see that the screw has tightened the nut moved into the plastic so the pressure is more evenly distributed.
i just used the same screws for the ones without the fsr plumbs and nutted them together with the snowflake to get them a tight grip.
[img]http://i.imgur.com/xSCIgKq.jpg[/img]
afterwards i used the Mhackney FSR Mounts i had to resize the plumbers to 98% to give them the good slipping fit they need.
Seconds before the first test
[img]http://i.imgur.com/f2nO12B.jpg[/img]
and IT WORKS
[img]http://i.imgur.com/8tiNx3v.jpg[/img]
thanks to the team for helping me out
i had to take the picture
[img]http://i.imgur.com/XQahdxX.jpg[/img]
Last edited by derzaubererer on Fri Oct 30, 2015 2:53 pm, edited 4 times in total.
Re: DerZaubererer's FSR Montage
Thanks for your post but your images did not show up.
derzaubererer
Eaglezsoar wrote:Thanks for your post but your images did not show up.
thanks i just fixed it :)
Yep, they work now! Great pictures and the cat picture added to my day! :)
The FSR setup looks good. I responded to your other post in my thread but it looks like you got it.
derzaubererer
mhackney wrote:The FSR setup looks good. I responded to your other post in my thread but it looks like you got it.
nice thats good to hear i just broke my borosilicate glass plate and i wont be able to print until maybe tuesday its a test to my patience:Y
derzaubererer
i got a new glass and im currently trying to calibrate with the fsrs but its off by 0.2 mms and the opendact tool cant seem to fix it anyone got some tipps?
Return to “The Build Zone”
