Heat up your bed 21.5% faster for pennies.
Posted: Sun Nov 01, 2015 5:06 pm
Hello,
I've read numerous threads on upgrading your ATX power supply to 24v from the 12v to get your bed hot really fast. I don't want to go through all that effort. Not to say that I'm the first to think of this, which I seriously doubt I am, but I thought I'd put together a fairly comprehensive analysis of how to heat it up faster with very little effort. Below is a graph showing the research I did using a control (no insulator), cardboard covered in aluminum, blue foam, and then blue foam covered in aluminum. The verdict is in and the blue foam covered in aluminum heats up the bed 21.5% faster than without it. I did each test twice, using precisely the same base temperature of 26.4c to 70c. This took me roughly 7 hours to do each of the tests twice, including bathing the glass in ice water to get it to cool down faster. I hope someone finds this research valuable. From now on, I'm using the blue foam insulator with aluminum because it really does make a difference!
