				Push button getting wore out?
				Posted: Tue Nov 10, 2015 9:04 am
				by Right to Make
				Push button on the LCD seems to be acting up. The push function seems less like a button and more stiff. If I push it harder it works, but not all the time. Anyone else get this issue. I have the V2. Everything else works great just the select function/push button. Could I lube the pushing mechanism in the button? I could not get the knob off I think its glued on. As always, thank you.
				Re: Push button getting wore out?
				Posted: Tue Nov 10, 2015 9:08 am
				Unless you glued the knob on yourself, it's not glued.
Check to make sure there's no debris under the knob.
Do NOT try to "lubricate" it.
				Posted: Tue Nov 10, 2015 9:51 am
				by JFettig
				I had the same problem, turned out there was part of a skirt under it. Pull the knob off and see whats up.
				Posted: Tue Nov 10, 2015 12:59 pm
				by Right to Make
				alright ill try that and update this
				Posted: Tue Nov 10, 2015 1:03 pm
				by Right to Make
				As always, excellent advise! I could not see anything but took some dental floss after pulling the knob off and went in between it and some filament (very small amount) was in there. Works like a charm. Thank you again. excellent forum!
