Rambo and the Viki Display
Posted: Mon Nov 16, 2015 7:14 pm
Has anyone successfully interfaced the Pannucatt Viki display with the Rambo controller and if so could you briefly tell us what needs to
be done to make it work?
Re: Rambo and the Viki Display
Posted: Mon Nov 16, 2015 7:59 pm
by Eric
There's nothing about the hardware that's incompatible. It's all about firmware support, and there are many firmware choices.
In Repetier it appears to be supported. Set FEATURE_CONTROLLER to 5 in "configuration.h". Also make sure pin assignments in "ui.h" are correct for whatever rambo pins you choose to use.
Can't help much beyond glancing at the code, as I don't own either a Rambo or a Viki.
