Injector types for the hotend, what are my options?
Posted: Sat Nov 21, 2015 8:19 am
by teoman
I would like to print some food items. What are my options for printing mushes .
If i get bored of food printing then a setup that could be converted to print ceramics would also be nice.
Re: Injector types for the hotend, what are my options?
Posted: Sat Nov 21, 2015 9:18 am
I'm not aware of any injectors for printing unless you buy an entire printer (the pancake printer). But there are designs on Thingiveres to make a simple screw drive extruder that will print a range of pushes.
Posted: Sat Nov 21, 2015 1:32 pm
by IMBoring25
The Fab@Home project had a syringe extruder too. I merely got some commercial syringes and have been planning to design a mount and extruder drive to accommodate them. Haven't gotten around to that yet.
Posted: Sat Nov 21, 2015 1:38 pm
by teoman
That is what i had in mind.
If the cold end is strong enough maybe a bowden setup can be used. I.e the filament does not go in to the hotend but pushes the plunger of the syringe.
Posted: Sat Nov 21, 2015 2:16 pm
There seem to be basically two approaches to this, either retrofit a syringe with a screw that will drive the plunger, or use a peristaltic pump. I think Richrap did some experiments in this space, so you might want to check out his blog.
Other sorts of pumps won't work because they pulse rather than giving a continuous stream.
Posted: Sat Nov 21, 2015 3:01 pm
by bot
I've also seen people on YouTube or somewhere online using an Archimedean screw to drive paste or concrete or something.
