slight lean to cylinder print
Tinker12
Post by Tinker12 »
I have printed several hollow cylinders about 3/4 inch dia and 1 and 1/2 inch high. the completed print looks good in
every aspect but there is a very slight lean to the vertical axis (like the leaning tower of pisa). can anyone comment of the possible cause and solution
to this issue.
thanks
Re: slight lean to cylinder print
Check that your u-joints aren't binding or sticking anywhere in their travel. Give them a drop of oil and move them around by hand to make sure that there aren't any tight spots.
teoman
Post by teoman »
Examine the part and try to determine if the bottom yayer is crooked r the whole thing.
Is it crooked upside down?
teoman
Post by teoman »
To determine if your bed is crooked or the arms are printing crooked.
Return to “ORION”
