Fighting nozzle gap at bed edges
Posted: Mon Nov 30, 2015 1:41 pm
Maybe that's not the most clear title? Allow me to explain.
Newb to printing. I built the Rostock Max V2 as my 1st printer and Ive had great luck with it on small parts no wider than about 3" total. Now as I stretch her legs and try to print a quadcopter frame (or anything that fills the outer edges of the bed) I get excessive gap between the nozzle and the bed in certain quadrants of the bed. Here's what Ive done multiple times:
- Readjusted the towers so they are at right angles to the bed.
- Done the tower cal macro so many times my head hurts. Getting great results with X,Y,Z nozzle/bed gaps being uniform.
- Adjusted Z height so many times as well as required after tower cal.
- Adjusted Horizontal Radius value a little and settled on 139.8 as it showed identical heights between center and xyz during tower cal macro.
- Removed bed and tightened screws.
- Turned bed leveling on (and setup) and off with no change in results.
Attached is a picture of what's happening, you can clearly see either the nozzle is lifting or the bed is dropping in the quadrant between X and Z, and squishing close to X. However, the center is always good and I can print well around the center out to about 3" from center. Im open to any ideas to get this right. Am I doing something wrong with this delicate dance between end stops, horizontal radius, and z height?
