Enclosure heating
Posted: Mon Nov 30, 2015 5:57 pm
				Will be receiving my Max2 soon and thought I'd start on an enclosure.  Decided on 1/4" plywood approx. 1" larger than the V2, with 18" wide clear PC front door.  I plan on using a 125W (or 250W) heat lamp bulb screwed to a porcelain base under the top assy of the V2.  I'd like to keep the heat above room temperature 24/7 (or at least in the winter when my garage is below 60F).  Will a water heater thermostat work at controling the temp within the enclosure?  Something like this?
http://www.amazon.com/gp/product/B001AT ... 1_3&sr=8-3
The filament reel on top will be within the enclosure. Should I add a small fan to circulate air (in the top section so there is little to no breeze below). Will be printing ABS.
PS: Holy crap, UPS just dropped off "the box"... ordered on Thanksgiving! Wife says "oh no, won't be seeing you for a while".
