While calibrating LCD went off.
Orellana.arch
Post by Orellana.arch »
Hey what's up guys hope all is well.
I just finished assembling the Rostock max v2 and was on the second phase (calibration)
I set the z axis and was up too the part where you set the towers stops. I applied the tower calibration g code and was adjusting the screws and all of a sudden the lcd went blank. like its not even on. I turned it off and back on. I try to connect to MatterControl and it wont connect anymore. wth happened lol everything was going so smooth?
please helppppppp lol
schlrobe
Re: While calibrating LCD went off.
Post by schlrobe »
Like me, it appears you accidentally managed to blow a fuse. It happens. ALOT. To me anyway...
Especially if (like me) you suck at crimping those super-tiny connectors onto cables. Sigh....
The replacements don't cost too much. I get mine from here http://www.digikey.com/product-search/e ... ano%20fuse
You can also try this link: http://www.digikey.com/product-search/e ... =5A%20nano
Select the 5Amp or 10Amp fuses. The Rambo is certified to work with either. Select the nano 451 fast acting.
Orellana.arch
schlrobe wrote:Like me, it appears you accidentally managed to blow a fuse. It happens. ALOT. To me anyway...
got it thanks alot man. i think you are right i was switching around the fuses and the lcd started working. thank you
