First 3D printer build - GlassRod85 - Rostock Max V2
Posted: Sun Dec 13, 2015 12:48 pm
Greetings! I am super excited to start my 3D printer kit build. I considered purchasing the Makerbot Replicator 2 last year but the high cost caused me to pause.
Seeing 3D printer sales on Black Friday(Amazon)lead me to research printers again. Reddit, https://www.3dhubs.com/best-3d-printer-guide, and finally the seemecnc forums helped me decide on the Rostock Max V2. A little disappointed since I missed the Holiday discount window (purchased Dec. 6th) which cost me at least $100.
Anyway, a little background on me. Chemist by degree. Not much experience with electronics or engineering. I dabble in woodworking, lampworking, gardening, and tons of books and computer games. I manage to build every IKEA style construction project backwards the first go-around, so this should be an interesting challenge.
Will be doing a completely stock build to get my feet wet and hopefully learn some 3D printing basics.
So far the instructions are phenomenal. My only suggestions/complaints up to this point have been the Onyx Heated Bed Assembly Section.
[list]
1.) The instructions ask for 14" 18ga wires to power the heated bed, but don't specify where to get them. Up to this point every wire had been cut to length, and parts not with the kit had instructions on where to find them, so I spent 15 minutes or so concerned I was missing a part until I finally decided it must be taken from the 8' wire bundle in the unlabeled baggie. Hopefully that was the correct assumption but if not I figured I could always locate a few more feet of wire and moved on. (I just noticed another build thread discussion had the same confusion)
2.) I was all worried about needing to get the PTFE wrapped thermistor leads flush with the back of the Onyx after seeing the 2nd install photo. The 90 bend copied from the first photo though was too far back to allow it easily. I probably manipulated a fragile part more than needed trying to improve this. It wasn't until I started adding bulky wires and so forth in later steps that I realized flush fit didn't matter much on the back. Might help to indicate that.[/list]
This build will be a little slow as I need to finish up a few other Christmas gift projects at the same time. Example below
[img]http://i.imgur.com/d4VuYx7h.jpg[/img]
hexagon shelves I'm building after someone wishlisted something similar on etsy.
Without further ado - here are the first of my build pictures. Build started at 19:00 on December 12th, 2015.
The Build Area
plenty of temporary table space
[img]http://i.imgur.com/je0SvOKh.jpg[/img]
Hot-End Assembly
A bit of cleanup needed. Hopefully will upgrade this portion in a few months after reading so many lackluster reviews. Definitely was a bit of a messy intro.
[img]http://i.imgur.com/scbYlJch.jpg[/img]
Power supply
Question on this part - I have a few spare modular computer PSU in the closet. Is there any significant reason to use one of those instead as I've seen a few builds try?
[img]http://i.imgur.com/dQ9V9Vyh.jpg[/img]
[img]http://i.imgur.com/r9ORHYsh.jpg[/img]
Wish me Luck!
[list]
The Build Area
Hot-End Assembly
Power supply
Wish me Luck!
