New style effector
New style effector
I tried searching but had no luck. is there an STL file for the new style effector? I want another one but the SeeMeCNC site only sells a kit that also includes the arms(came with the printer).
Re: New style effector
The STL file should be on their github repo somewhere, but I bet if you email them they'll sell you any individual part you want.
The file is called 68304 platform by seemecnc.stl and is located here: https://github.com/seemecnc/RostockMAX/ ... emecnc.STL
I believe there is a top and bottom that are two different files.
Sorry Eaglezsoar, my effector looks nothing like that. I have the new style with the nylon? ball joints. Thanks for the idea geneb. I will email SeeMeCNC.Eaglezsoar wrote:The file is called 68304 platform by seemecnc.stl and is located here: https://github.com/seemecnc/RostockMAX/ ... emecnc.STL
The unit comes apart so fast. I think it's a great design.
I want to make some hot ends that I can swap out fast, just pop off the arms and plug in the new hot end.
I have been searching Github and all I have found is this: https://github.com/seemecnc/RostockMAXv ... ints-1.STL
- nitewatchman
Try this one, I think it is what you are looking for.
- New Effector_Old Hot End Assembly - 70857 Ball Joint Platform-1.stl
- (789.93 KiB) Downloaded 275 times
