Rambo End Stop Connector
Posted: Tue Dec 29, 2015 4:34 am
by Pyropainter
My intention is to get my Rostock Max v2 set up so I can utilize the Open DACT software on my machine. I realize that I will need to add a micro switch to the existing electronics of my machine. The trouble that I am having is locating a supplier that sells the connectors that plug into the Rambo board. I am sure that I am Googling the wrong questions. Will you help me locate someone that sells the connector that allows micro switches to be connected to the Rambo Controller. Please add the correct name for these connection so that I may know what to call them the future.
Thank you in advance.
Re: Rambo End Stop Connector
Posted: Tue Dec 29, 2015 5:56 am
by magicmushroom666
Dupont connectors are a good start. You can always use those with standard pitch headers.
Posted: Wed Dec 30, 2015 3:32 am
by Pyropainter
Thank you for your help. I got to thinking that these connectors look similar to the ones used in the RC Model Airplane World (something I pretended to do in another life). I dug thru some of my old stuff and found some old servo connectors and extensions. I believe I will try this for now. What I would like to find is a connector that has the retaining mechanism. Anyone have a source for them?
Thank you.
Posted: Wed Dec 30, 2015 5:25 am
Pyropainter wrote:Thank you for your help. I got to thinking that these connectors look similar to the ones used in the RC Model Airplane World (something I pretended to do in another life). I dug thru some of my old stuff and found some old servo connectors and extensions. I believe I will try this for now. What I would like to find is a connector that has the retaining mechanism. Anyone have a source for them?
Thank you.
See here: http://www.hansenhobbies.com/products/c ... in_lp_1x4/
Posted: Fri Jan 01, 2016 4:31 pm
by Pyropainter
Thanks for your help, I will check them out.
