				Rostock base panel for 92mm fan
				Posted: Thu Dec 31, 2015 6:59 am
				by thedoble
				I wanted to get a bit more airflow happening inside my rostock's base. I found my steppers get quite warm.
I'm also learning a new design package - Autodesk Fusion 360. Coming from Sketchup, it's a beast! I figured this would be a nice, simple design so I can start to learn how to model in Fusion.
Anyway here's the finished design, am printing it now. Hopefully I got my measurements for the holes right!
[img]
http://i.imgur.com/0c0bzai.png[/img]
				Re: Rostock base panel for 80mm fan
				Posted: Sat Jan 02, 2016 2:48 am
				by thedoble
				I got this idea from another design on thingiverse - added a 45 degree duct.
This should direct the air onto the X/Y steppers and past the electronics. I made the plate able to be installed upside down so you can have one on each side of the base and get PUSH>PULL airflow throughout.
[img]
http://i.imgur.com/FzJf1yF.jpg[/img]
				Posted: Sat Jan 02, 2016 8:47 pm
				by Windshadow
				Looks good but you might want to make a provision for an intake filter if you are sucking air in with the fan when I used to build my own PCs I found that cut up chunks of Airconditiong filters over all the places that air was being sucked into a case helped a lot with longevity and then I realize that if I changed the air flow of the the case fans so that they sucked in the air rather than blew it out I just needed to filter the fan intakes
I have been thinking about the Peek fan and wondering if I should do something to keep dust etc from the cooling ridges of the PEEK
				Posted: Sun Jan 03, 2016 8:21 am
				by thedoble
				Windshadow wrote:Looks good but you might want to make a provision for an intake filter if you are sucking air in with the fan
Good idea, especially considering there's likely to be bits of filament floating around near the printer base.
You could simply put a bit of gauze or mesh over the front of the intake. I'll see if I can come up with a way to do it.
I finalized the design tonight - I didn't want to bother with finding the right length screws for the fan, so I made some little pegs - the fan clips on quite nicely and is held very snug.
[img]
http://i.imgur.com/bN2RVHL.png[/img]
				Posted: Sun Jan 03, 2016 9:32 am
				by jesse
What did you use to generate this image?
				Posted: Sun Jan 03, 2016 9:35 am
				by thedoble
It's auto-generated by repetier-server
You can take a look if you like - it's printing now.
http://3dprinting.thedoble.com
There's a webcam too
				Posted: Sun Jan 03, 2016 10:30 am
				by Xenocrates
				You play Eve Online, Don't you?
				Posted: Sun Jan 03, 2016 4:41 pm
				by thedoble
				Xenocrates wrote:You play Eve Online, Don't you?
I used to
 the vexor is for a friend
				Posted: Mon Jan 04, 2016 12:16 am
				by jram
				Nice work! I have also been using fusion 360 quite a bit. I'm loving it thus far.
				Posted: Tue Jan 05, 2016 7:41 pm
				by thedoble
				Finished!
This came out awesome, really pleased with it. The fan clips are great - they're VERY snug and the fan goes on with a nice 'click' !
[img]
http://i.imgur.com/UuEG40v.jpg[/img]
[img]
http://i.imgur.com/t6z0Q8z.jpg[/img]
[img]
http://i.imgur.com/VhBRSfe.jpg[/img]
Timelapse of the print:
https://youtu.be/6_Ts2lltWGQ (I couldn't get the youtube tag to work)
I'm going to print a 2nd plate for the other side so I can get some nice airflow happening.
Here's the link to the thingiverse download:
http://www.thingiverse.com/thing:1248005
				Posted: Tue Jan 05, 2016 9:11 pm
				by Windshadow
				nice work I have yet to try anything that large a clever design as well
				Posted: Wed Jan 06, 2016 11:46 am
				Thanks for creating this and posting the files!
				Posted: Wed Jan 06, 2016 1:37 pm
				by gchristopher
				Those look very nice!
