Mac Software issues
Posted: Mon Jan 04, 2016 7:01 pm
I can't believe after a smooth build I am having issues with software on a Rostock V2.
I had prepared my oldish G4 iBook to use with the new 3d printer. It was running Lubuntu lean and fast. But it just turned out that installing Arduino software was a bit more complicated than expected. No problem, really. I did a fresh install of OSX 10.4.11 - last OSX to run on this. Installed Arduino 1.0.6 and without problems uploaded firmware to the Rostock. Next was the fun part installing MatterControl - oops, needs OSX 10.7 or later. Can't find an older version.
It would have been so nice to use the small laptop with the printer - the printer is so much harder to move to where my bigger computers are. But, ok, move the printer upstairs. Hooked it up to Mac Mini running Yosemite. Downloaded Arduino 1.6.7 and MatterControl. Everything starts up..... but trying to compile/upload firmware (Repetier) I get error: can't compile, file not found (twi.c) - or something like that. The file is obviously being included in the code, it's present in the libraries where it should be and Arduino 1.0.6 finds it on the laptop. Ok, so I tried to remove Arduino 1.6.7 and install 1.0.6 but this will not at all compile Repetier on Yosemite.
I realize that once I have the firmware on the Rostock I might not necessarily need Arduino. But I would really like to have all these tools running on the same machine.
Any ideas from anyone?
Thanks
Thanks
