Swiss Clips - Potential improvement for heated bed clips
Posted: Sun Jan 10, 2016 6:22 am
by ccavanaugh
I've seen these start to show up within the RepRap community.
They are a lower profile heated bed clip than the binder clips we typically use.
Cost is a bit higher unless purchased wholesale in larger quantities, but it would be better for printing out to the edge and clearing the effector with low profile layer fans etc.
http://www.dickblick.com/items/18912-9434/#photos
https://reprappro.com/documentation/orm ... -assembly/
http://www.3dprintandstuff.co.uk/shop/g ... wiss-made/
Re: Swiss Clips - Potential improvement for heated bed clips
Posted: Sun Jan 10, 2016 1:02 pm
I saw these, too.
http://www.robotdigg.com/product/627/Cl ... to+heatbed
It made me wonder if anybody was using them already.
Posted: Sun Jan 10, 2016 2:57 pm
by IMBoring25
My Mendel started life as a RepRapPro kit and uses these. Seeing this thread, I pulled one off and tried to clip it on the Rostock just for grins. With the stock bed installation it hits the snowflake before it gets far enough inboard to grip the edge. It's also really fiddly with the printer base so close under the bed. I had to shim the leading edge (relative to the installation motion) up with a set of needlenose pliers to keep the spring from rotating the clip out of position.
Posted: Sun Jan 10, 2016 4:20 pm
by ccavanaugh
IMBoring25 wrote:My Mendel started life as a RepRapPro kit and uses these. Seeing this thread, I pulled one off and tried to clip it on the Rostock just for grins. With the stock bed installation it hits the snowflake before it gets far enough inboard to grip the edge. It's also really fiddly with the printer base so close under the bed. I had to shim the leading edge (relative to the installation motion) up with a set of needlenose pliers to keep the spring from rotating the clip out of position.
Good to know... Thanks!
Posted: Sun Jan 10, 2016 7:06 pm
by teoman
Thank you for the test! Saved a lot of us some time.
