Rostock Max Limit switch wiring issue
Posted: Thu Dec 20, 2012 4:12 pm
My RAMBO has 1 longer wire pair and two shorter ones or the endstops.
The longer one has to be for the Z Axis since it has to run further, but I can't see how to run the X Axis wire so it will reach the sockets on the RAMBO.
I have my RAMBO mounted on the inside per the PDF with the stepper drivers to the bottom.
After the wire exits the extrusion, it has to go left through the slot, which is away from the electronics compartment.
AFAICS It then has to go around the TSlot support before it can be routed into the electronic compartment.
when I do this, the wire is about 2 inches too short to reach the X endstop connectors, even with the door closed.
Am I missing something here?
