Page 1 of 3
Mostly Printed CNC Router
Posted: Sat Feb 13, 2016 5:37 pm
by barry99705
I suppose I'll start a build thread for this. It's a long term project. Building as extra funds become available. Here's the creator's site, and the thingiverse page.
This is the middle assembly. It's what the Z axis will connect to.
[img]https://lh3.googleusercontent.com/--Xq1 ... 170105.jpg[/img]
[img]https://lh3.googleusercontent.com/-Shnp ... 170115.jpg[/img]
[img]https://lh3.googleusercontent.com/-s3C8 ... 170134.jpg[/img]
Here's one of the roller assemblies. They are where the X Y steppers get mounted. The screws on the side are for the wiring, no soldering needed!
[img]https://lh3.googleusercontent.com/-Vd5f ... 170156.jpg[/img]
The fender washers have a bearing behind them. The stepper will have a gear that the belt will go over then under the bearings to the corners of the router.
[img]https://lh3.googleusercontent.com/-BtkM ... 170209.jpg[/img]
And the corner blocks, kinda self explanatory..
[img]https://lh3.googleusercontent.com/-UZw6 ... 173536.jpg[/img]
[img]https://lh3.googleusercontent.com/-wExW ... 173539.jpg[/img]
Re: Mostly Printed CNC Router
Posted: Sat Feb 13, 2016 6:22 pm
by Captain Starfish
Neat-o!
Looked so lightweight and spindly on his photos, but seeing the carriage in your hand gave it a bit more perspective. Gonna be a pretty chunky little machine when you're done!
Posted: Sat Feb 13, 2016 8:36 pm
by Windshadow
I look forward to reading your build thread . it looks like a very interesting machine how big do you plan to make it?
Posted: Sat Feb 13, 2016 10:02 pm
by barry99705
Captain Starfish wrote:Neat-o!
Yea, that middle assembly has some heft to it. There's 24 bearings in just that part!
Windshadow wrote:I look forward to reading your build thread . it looks like a very interesting machine how big do you plan to make it?
I think I'm going to start out at his stock size, which is I think about 2 foot square carving area. I'm hoping to get it out to about 4 foot carving area when I'm done though. I'll have to go stupid slow at that size, but that's okay. I'm hoping to be able to use it to make parts for this.
Posted: Sat Feb 13, 2016 10:21 pm
by Windshadow
Very Cool I have seen an antique tablet with i guess a similar mechanism there was a huge fad for morphing furniture in the 19th century i understand.... it looks to be a very challenging project will you be doing exotic veneers as well? the antique i recall was all in solid oak but it had a lot of relief hand carving on it in the late 19th century craftsman style will you use the Makita or Dewalt trimmer for your spindle?
Posted: Sun Feb 14, 2016 12:11 pm
by barry99705
Windshadow wrote:Very Cool I have seen an antique tablet with i guess a similar mechanism there was a huge fad for morphing furniture in the 19th century i understand.... it looks to be a very challenging project will you be doing exotic veneers as well? the antique i recall was all in solid oak but it had a lot of relief hand carving on it in the late 19th century craftsman style will you use the Makita or Dewalt trimmer for your spindle?
Probably the dewalt. Haven't decided on the table top yet though. Will probably use oak veneer plywood for the top, and something else for the parts that come up from underneath.
Posted: Sun Feb 14, 2016 12:49 pm
This is one thread that I cannot miss, thanks for posting it!
Posted: Sun Feb 14, 2016 4:16 pm
by barry99705
Rails are installed! Going to have to resquare everything when I mount it to a table. Just wanted to see it put together, I'm impatient like that... :lol:
Tubes are 30ish inches each, plus or minus an eighth inch depending on which way my pipe cutter blade wanted to flex.
[img]https://lh3.googleusercontent.com/-1cLz ... 163904.jpg[/img]
Crap. Just realized the corner blocks are all backwards... :roll:
There, that's the way they should be!
Heh.
[img]https://lh3.googleusercontent.com/-we7F ... 550916.gif[/img]
Posted: Sun Feb 21, 2016 11:06 pm
by barry99705
[img]https://lh3.googleusercontent.com/1NWHV ... 4-h1075-no[/img]
Now I just have to get the electronics, steppers, belts, and gears! Also need to actually mount it to something, then level the legs.
1 liter dew for scale.
Posted: Mon Feb 22, 2016 11:36 am
by Tincho85
I thought I was done... but you gave me CNC fever again, now I want one too! :D
Keep posting please.
Posted: Mon Feb 22, 2016 8:21 pm
Still looking cool! I am very much interested in this project.
Posted: Wed Feb 24, 2016 8:36 am
by davec3275
Nice work! Looks great! This is such a fun project to build. I am just working on my spoil board for mine and then I can get to actually cutting parts.
Posted: Fri Feb 26, 2016 2:10 pm
by Tincho85
Posted: Fri Feb 26, 2016 5:47 pm
by Captain Starfish
Suggestion: if you can find the bucks, a VFD controlled water cooled high speed spindle with an ER16 or ER20 collet will run smoother and ~so~much~quieter~ than a router. They can be had outta China for $300-$400 or so IIRC. Your neighbours, your dog and your own ears will thank you for this investment plus you'll be able to tune feeds and speeds to get a better finish and so on.
Posted: Fri Feb 26, 2016 6:55 pm
by cope413
Posted: Fri Feb 26, 2016 8:06 pm
by Captain Starfish
That looks pretty much like the spindle on my X2200L. Heaps of grunt and the ER-20 collet means I can go up to 1/2" tool shanks. It might be a bit heavy for throwing around on the machine in this thread, though. I'd look at the 800W equivalent, probably.
http://www.aliexpress.com/item/800w-spi ... 96808.html
Sadly it looks like most of these VFDs want 220V input, not 110.
Posted: Fri Feb 26, 2016 8:18 pm
by barry99705
Yea, if I'm going to spend that much, I'll build a full sized all metal router. I live on 3 acres and have a barn, so not too worried about the noise! This will probably be a gateway drug anyway, will eventually build a bigger one. :lol:
https://goo.gl/photos/MsEREebu2WFtrjoH8
Posted: Fri Feb 26, 2016 9:01 pm
by Captain Starfish
Plenty of room for a bigger shed then! :D
Posted: Fri Feb 26, 2016 10:38 pm
by barry99705
Captain Starfish wrote:Plenty of room for a bigger shed then! :D
Heck yea!
https://goo.gl/photos/wtuEinXSJRpJuWA67
Here's the barn before we moved in. My forge is downstairs.
https://goo.gl/photos/TpgiTQqG2jD9iBfj9
Posted: Sat Feb 27, 2016 12:48 pm
Heck yea!
https://photos.google.com/album/AF1QipO ... UwV6rMV5Ld
https://photos.google.com/album/AF1QipM ... VFrgvlUgQG
Hey Barry, your picture links do not work, but I appreciate that you tried!
Posted: Sat Feb 27, 2016 8:56 pm
by barry99705
Eaglezsoar wrote:
Heck yea!
Heh, oops, fixed it. Still getting the hang of google photos, picasa was so much easier... :roll:
Posted: Sat Feb 27, 2016 10:21 pm
by Captain Starfish
Nope, still wants me to sign into google to see them. :/
Posted: Sat Feb 27, 2016 10:42 pm
by Windshadow
You have to click the links in the original post then it worked for me but I do use google so it may be the reason.
Nice workshop space plenty of room and what looks like a fire-resistant forge area... nice job on the rebar tongs too
Posted: Sat Feb 27, 2016 11:40 pm
by Captain Starfish
Good call, that worked nicely.
Wow. So much room to grow and collect! :D
Posted: Mon Feb 29, 2016 1:21 am
by dunginhawk
Good morning gents and ladies :)
I havent been on the boards here for a while as I no longer own my max v2... Ive always been a fan of the community here though.
So i thought id chime in (not to hijack).
This MPCNC this is FOR REAL. I just finished mine a couple of weeks ago and its fantastic. It works really really well, and its cheap.
If you can print your own parts (of course you can, you have a rostock max v2 or an orion) you can get the rest of the router done for under $300.
My first project was creating a chess board to go with my DLP resin 3d printed parts.
The board turned out awesome. The tolerances of the cut were perfect. This board required no sanding. It was perfect.
So anyone who started hearing about the MPCNC on this thread, rest assured, its awesome.
the youtube link below is my chess board/set video.. start to finish my entire process
https://youtu.be/19-m_SUNRqs
