only 9V to heated bed
Posted: Sun Feb 14, 2016 7:12 pm
I have a Rostock MAX v2, the new version from fall of last year with the new PSU. I'm not happy with the heated bed ramp time (much slower than my Ultimaker). I finally had things taken apart a bit (replacing a burned out nozzle heater and making my hot-end wiring completely detachable), so I started digging a bit more.
step #1: I pulled of the heated bed to check my solder joint (it gets kind of squished in there when assembling). Looks nice and solid, no tight bend, no cracking, full pad covered.
step #2: check for PSU voltage droop when the bed is heating.
Results:
heater off: 12.24 at the PSU, 12.22 at the input to the board.
heater on: 12.18 at the PSU, 12.10 at the input to the board.
Pretty healthy, no droop that would significantly slow things
step #3: what voltage is the bed actually getting during heating?
9.2v measured at the output of the board! This is measured with a DC setting on a fluke multimeter, and it is jumping around a bit (+- .5V). The light is also flickering, quite visible to the eye. I assume that it is getting pulsed, on ~3/4 of the time. This is with the bed at 40 with a target of 100, so it should be full on.
It appears I have 30% more power potentially available.
I'm going to poke around in the settings and see if if there is any limiter I'm not aware of. I'll also poke through the calibration steps again to see if I missed something.
If not, I'll need to bypass the board and put in a separate relay or driver.
Is the driver not able to handle full on? Or do I have a PID calibration problem?
Results:
