Ticking Power supply?
Posted: Fri Feb 19, 2016 1:32 am
by Jrjones
So it appears my power supply has developed a tick, or a drum set.
I was wondering if anyone else has had this happen before? It was completely silent (except for fans) up to yesterday, and ticks each time the heated bed power switches. I can hear over the stepper motors while the printer is printing.
I don't hear anything when the hot end cycles.
I don't think it could be the rambo board, so I figured it would be the power supply (a 360W 12V LED style power supply, similar to the new ones SeeMeCNC uses).
A video of the ticking: https://onedrive.live.com/redir?resid=E ... ideo%2cmp4
I haven't opened the printer yet to examine the power supply closer, I'm going to try to that this weekend.
If anyone has any ideas of what it could be I would appreciate it.
Re: Ticking Power supply?
Posted: Fri Feb 19, 2016 4:25 pm
by teoman
Sounds like a relay.
Posted: Fri Feb 19, 2016 6:42 pm
by thedoble
Yeah, seems to have that on/off sound of a relay.
I suggest against dismantling the power supply unless you really know what you're doing. Better to just replace it, they're cheap enough.
Posted: Fri Feb 19, 2016 9:16 pm
by teoman
My psu also does click (24v) i think it is for different power modes or the fan. Has not bothered me so i did not investigate further as it has done it since day one.
Posted: Fri Feb 19, 2016 10:08 pm
by Jrjones
I would say a relay as well, but there's no relay anywhere on my printer or PSU
Hmm weird, I took my power supply out of my printer to try and localize the click noise, and now it doesn't make it anymore.
teoman, I think my psu's fan is a simple on/off switch. It uses a temperature switch similar to this one to control its fan: http://www.frozencpu.com/products/16492 ... html#blank
Posted: Sat Feb 20, 2016 8:56 am
Jrjones wrote:I would say a relay as well, but there's no relay anywhere on my printer or PSU
Could it possibly a fan on your printer making that clicking noise?
Posted: Sat Feb 20, 2016 10:22 am
by magicmushroom666
Could be a bad connection between the power supply and rambo. If there was a bad connection (higher resistance) then the large current draw from the bed would pull the supply down to everything else, (assuming they are on the same supply cable) and this changing voltage could be audible in something mechanical such as a fan or the motors.
