Access Denied to COM Port
Posted: Sun Feb 28, 2016 5:06 pm
Hello everyone,
I had my printer working fine a week or so ago and when I went to start it and run it yesterday, I kept getting an error saying that the COM port was taken and access was denied. I received the same error from Repetier-Host and Arduino. So I am doubting that the software is the issue.
I have the driver installed from the RAMBo wikipedia page. Under my device manager, it is showing the device as RAMBo, so I believe that is fine.
I thought maybe the USB connection on the RAMBo board was broken so I tried wiggling it and eventually was able to connect it after holding it some weird way and disconnecting and reconnecting it, I got it to connect. So after this, I thought I was going to have to solder it back on. I disconnected all the wires and removed the RAMBo. To confirm that the connection was the issue, I plugged the cable in and tried to connect to it. However, this time I was unable to connect even with wiggling the cord and such. I probed the four solder joints on the RAMBo board where the USB connection leads. Vcc and Ground were reading ~5V, even with wiggling the cord. The data lines were also reading a voltage ~3.33V, but I don't have an oscilloscope to actually test if these are transmitting data correctly. Therefore, I am kinda doubting that it may be a bad connection.
I also tried a different cable, specifically the one that I use for my printer, and I had the same issue.
Do you guys have any more ideas on how to diagnose this issue? My next plan of action is to try a different computer.
