Can someone with a kraken please tell me what I might be doing wrong or how you got the tubing secured on the cooler block with the supplied couplings...Thanks!
Rodney
I am glad that you succeeded!Cobaltrod wrote:Okay, that was it. The needle-nose players would slip. it took a little bit of brut force, but with a firm grip with wire cutters on the tube closer to the coupling, I was able to get the tube through the coupling and into the heat break. Finally!
